It is currently Thu Jun 26, 2025 7:03 am
PostPosted: Sat May 20, 2006 2:17 am
Here is my latest rosette. I made all the parts including the rope and tiles, however I have some areas that need touched up and am not sure how to proceed. If you look close at the tiles, there are some white glue lines where some of the tile edges didn't meet up perfect. I didn't notice this until I planed the rosette flat with the top. Now that the rosette is done, is there any way to dye or color the glue line black so it's less noticable once I finish the top? Any help would be greatly appreciated.
Thank you!
PostPosted: Sat May 20, 2006 2:38 am
John try taking a sharpie (or a good art ink pen) and just *lightly* touching those spots, let it dry and again *lightly* shellac the rosette...
You should be fine after that...
-Paul-Sprockett38857.4856597222
-Paul-
Patriot Guitars
PostPosted: Sat May 20, 2006 3:52 am
I like Paul's idea. It might be a little tricky, though, where the white lines are right next to some white tiles, cuz a sharpie's ink can bleed a lot.
If this were my rosette, first of all, I'd give it a couple of wash coats of shellac. Next, I'd get a sharp X-acto knife, don some magnified optics, like an optivisor, and then gently scratch into the white lines until I had channels. Then I'd take some ebony dust and brush it into the channels, and drop some CA over them. Sand it down, and the white lines should be gone.
Oh, and nice looking rosette, btw.
Best,
Michael
Live to Play, Play to Live
PostPosted: Sat May 20, 2006 4:24 am
True masterpiece rosette!
PostPosted: Sat May 20, 2006 8:14 am
Very nice work John! Arts and crafts stores have fine tipped pens for caligraphy etc. and they should do the job just fine.
PostPosted: Sat May 20, 2006 9:55 am
John, that's awesome. I love the rope.
PostPosted: Sat May 20, 2006 10:00 am
John, Your rosettes are quite impressive.
PostPosted: Sat May 20, 2006 12:29 pm
Thanks fellas,
I appreciate the comments! I think I will give a couple of the ideas a try starting from easiest to hardest, and maybe I won't have to go any further than the first try. I'll post feedback and pics to let you know how it worked.
Thanks again!
PostPosted: Sat May 20, 2006 12:45 pm
Great work john...how much time does that take?
PostPosted: Sat May 20, 2006 12:50 pm
John,
I guess I'm a bit more concerned about bleed-through than others, so I have a recommendation. Try the pen solution on an area of the rosette that will be covered by the fingerboard. Color in one of the white squares that's adjacent to another white square and observe the results.
Best,
Michael
PostPosted: Sat May 20, 2006 1:58 pm
John that IS really nice.
And a bold move to use turquoise (or is that green?) lines for the inner and outer bands. Black is so forgiving, but that light color shows off your handiwork to great advantage.
PostPosted: Sat May 20, 2006 2:14 pm
Very nice rosette John.I'd like to try that rope sometime,It's awesome. I think the art store pen should do the trick.Good luck with it.
PostPosted: Sat May 20, 2006 2:21 pm
I like
PostPosted: Sat May 20, 2006 8:34 pm
John, lovely rossette, would it be possible to scrape a small line where the white is showing and put in some of the black CA? I know Stew Mac carries black in a medium thickness that shouldn't wick to adjoining tiles.
